Updated Turbo Build Pics (Lots of Pics)
Old 06-09-2013, 02:11 PM
Ping King's Avatar
Default Updated Turbo Build Pics (Lots of Pics)
So i made some changes to my setup over the spring. Im not quite 100% done though, there are some minor adjustments to be made. Most importantly i need to make up some AC lines. Heres the rundown on the setup:
Stock Pass F body manifold with a Flipped Truck on the DS. Twin Deltagates. Garret GT4088R Turbo.
The changes i made:
1. Moved to a 4inch A2A Intercooler (previously had small A2W IC)
2. Changed hotside to 2 inches from 2.5. I used a Powerstroke Merge
3. Swapped Turbine Housing from .86 to .96
4. Full 3.5 exhaust (oval pipe from k member to rear of trans)
5. Recirculate wastegates back into the exhaust
6. Custom Be Cool dual pass radiator with surge tank
7. New alt Relocation Bracket from Modular turbo
8. MSD 2 Step
9. UMI K member with custom mounts (by me)
10. Catch can systems mounted behind headlights. Exhaust Evac built in.
Old 06-09-2013, 03:18 PM
RonSSNova's Avatar
Very nice work!
Top Notch.
Ron
Old 06-09-2013, 06:55 PM
Ping King's Avatar
Thanks. Its been a ton of work.
Quick Reply: Updated Turbo Build Pics (Lots of Pics)
