AEM Wideband to HPtuners
I am attempting to hookup my AEM UEGO wideband to HPtuners. I see that the white wire from the wideband goes to pin 1 and the black/ground wire goes to pin 5 on HPT's green connector. Is there anything else I need to worry about? I've read that I have to input the voltage offset (or something like that). What does that involve. Thank you.
You have the physical connections right, and you have to set the slope. Do you plan on using this for AFR or Lambda?
I have a a confg file that you can use that is set up for Lambda error, which makes it easy b/c all you have to do is multiply the existing values by the number in the histogram. Don't have my laptop on me at the moment though.
