t56 Rebuild Question
Hello, I got a quick question about the assembly of the T56. I just finished up sealing and bolting up the adapter plate to the case and now the main shaft and input shaft does not spin. I believe that the friction cones may be pressing against the gear. It happened to me before during a dry run to make sure I had all set up correctly. I wanted to know would I need to pull it apart and brake it loose, or will I be able continue the build and shift it loose?
Thanks
Thanks
