Fuel pressure or injector
Ok i ran 11.80 last week then 30min run at 13.0 my fuel is at 60psi but when i turn the car off it goes to 0psi in 2 hours and before it would stay at 45psi. it like it has a bleed off problem. is it a injector or fuelpump and the right o2 is all over the map and i put a new one on, and still the same reading with the hp scanner. need help big time. have a big race next weekI MEAN FUELPUMP GONE
So you have 2 WB O2 sensors and the one on the right side is all over the place and not reading steady? You replaced the sensor and it does the same thing? Just trying to understand, your post isn't really clear.
If this is true, it sounds like an injector is causing your problem. Go into more detail about the O2s reading all over the place.
