Map sensor
I have mine on the intake under the carb.
I screwed a hose barb in the intake and have a 1" piece of hose connecting the two. (took off the rubber bushing from the sensor)
http://shop.advanceautoparts.com/web...lVehicle=false
Any generic sensor that fits the harness plug will work. I pulled one of of a V6 GM motor. I mounted a small sheet metal tab on one of the coil pack bolts and hooked this to the carb with a 4" piece of hose. New ones are outrageously expensive. junk yards will give them away if you buy something else
