Programmer and 2 step wiring. HELP
Old 06-21-2013, 08:44 PM
jenkinscody21's Avatar
Default Programmer and 2 step wiring. HELP
Ok i have a 6 speed ls1 with a nitrous outlet plate system. I have purchased an LNC2000 from lingenfelter for a timing retard and 2 step. I also have the NOS mini controller for my nitrous. Ok here is my problem. I want to flip a toggle to activate the system in staging. However if my window is set 3500-6200, how do i wire this up to when i am launching the car at 4000rpm (momentary switch pressed), not activating the nitrous. Basically i want to bypass the system when this momentary switch is pushed
Old 06-21-2013, 10:44 PM
swoop's Avatar
Look in the instructions for the lnc-2000. If I remember right they show a diagram for using a relay to by-pass the nitrous.
Quick Reply: Programmer and 2 step wiring. HELP
