Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
New Racetronix F99+hotwire
Old 06-22-2013, 12:17 PM
maroonls1z's Avatar
Default New Racetronix F99+hotwire
Category: Accessories
Price: $200
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): TX
Item Condition: Brand New
Engine: LS1/LS6
LS Engine?: Fits LS Engine
Brand new racetronix F99 pump with hotwire kit with upgraded ground with port for BAP. Only pump, filter sock, wiring harness and instructions.
$200 + shipping firm
save about $40
[IMG][/IMG]
Old 06-22-2013, 06:35 PM
maroonls1z's Avatar
I paid 250 for the combo, can support up to 600rwhp, only opened the box
Old 06-23-2013, 04:06 PM
maroonls1z's Avatar
The Pumps
The Racetronix F-LS1 pump assembly is based on Walbro gerotor pump technology utilizing the most powerful armature and gear set currently available. Walbro has set the industry standard in high-performance in-tank pumps. Walbro pumps are QS9000 certified and are used as OE equipment in many production performance vehicles such as the C5 Corvette. Walbro's gerotor design is able to maintain high pressures while providing high volumes as well. This is done by squeezing the fuel out between two gears instead of pushing it like most factory vane pumps do. (i.e. factory F-LS1 pump). This positive displacement design makes high-performance Walbro pumps small, light weight, quiet, efficient and reliable. Tests in the field have proven the Racetronix F99+ system will support upwards of 600RWHP and 700RWTQ in some applications.
The Wiring Harness
High performance fuel pumps need a good power source in order to perform to their full potential. On average a Walbro high-performance fuel pump requires twice as much power as a factory fuel pump. Factory wiring is just enough for a factory pump’s power requirements because manufacturers need to save cost and weight. Racetronix field tests have shown that running a high-performance fuel pump off of the factory wiring can cut pump performance by 30% or more. Problems with failing factory relays, connectors/terminals and fuse contacts are also common when excessive load is placed on them.
The Racetronix plug and play harness is designed to remove all fuel pump load from the factory pump circuits while providing the pump with a new heavy-duty power source. The Racetronix harness gets its power directly from the alternator's battery terminal. The voltage at the alternator’s output is typically 1-2 volts higher than at the battery when the motor is running (high charge/load conditions and WOT). This means that your Walbro high-performance pump can provide as much as 20% more fuel in some cases. The Racetronix harness uses high-quality automotive-grade wire which is resistant to oil, gas, heat and rot. The main length of wire in the Racetronix harness is ten-gauge stranded copper. This is three to four gauges thicker than factory wire which helps reduce resistive power loss to almost non-existent levels. This helps improve pump performance by as much as another 10-20%. High-quality weatherproof fuse holders and relays are used for maximum reliability. The Racetronix harness has factory-type connectors which plug directly into your fuel pump module/sender so no cutting or splicing is required. The Racetronix harness has a redundant ground upgrade as it is necessary to improve the harness on the negative side of the pump's supply as well.
Racetronix harnesses are considered the best by which all others are judged. Attention to detail in every Racetronix harness is evident at first glance. Racetronix spares no expense to ensure reliability, ease of installation and performance.
All Racetronix harnesses are assembled using our computerized crimp-quality monitoring system and then circuit checked for the utmost in reliability. As with most Racetronix harnesses the F99-FPWH is backed by our limited lifetime warranty.
Old 06-24-2013, 06:47 AM
maroonls1z's Avatar
bump...
Old 06-25-2013, 07:13 AM
maroonls1z's Avatar
bump...
Old 06-28-2013, 02:54 PM
maroonls1z's Avatar
still for sale
Quick Reply: New Racetronix F99+hotwire
