please help. switching fro 2bar map sd back to stock
Old 06-29-2013, 12:39 AM
usafws6's Avatar
Default please help. switching fro 2bar map sd back to stock
how do i switch back to the stock maf tune without the orginal tune file? car is an 02 z06. thanks in advance
Old 06-29-2013, 03:50 AM
MontecarloDrag's Avatar
Not possible.
If you don't have the original tune, the only way to revert to stock MAF tune is downloading a stock tune with same OS ID, then flash it to the PCM.
Old 06-29-2013, 05:52 AM
Old Geezer's Avatar
As Monte said.
Look here for the stock tune: www.tunedepot.com
Old 06-29-2013, 10:27 AM
usafws6's Avatar
Do I have to license the original tune once I have it? And in order to flash it I have to do a write entire correct.
Old 06-29-2013, 03:31 PM
LSX Power Tuning's Avatar
You will have to license a new stock tune if you dont have the orignal stock file you licensed. Yes you want to do a write entire go to back to stock from 2 bar.
Quick Reply: please help. switching fro 2bar map sd back to stock
