Ram flywheel with McCleud Clutch, Can Ram Flywheel be turned?
Old 06-30-2013, 09:46 PM
VandykeT/A's Avatar
Default Ram flywheel with McCleud Clutch, Can Ram Flywheel be turned?
Right now I'm running a Ram Billet Flywheel and Ram Powergrip HD. The set up now is working fine but when the HD bites the dust I'm going to go back with either a RST or RXT. I assume the clutch will work with my current flywheel but wanted to make sure and can the RAM flywheel be turned? Thanks
Quick Reply: Ram flywheel with McCleud Clutch, Can Ram Flywheel be turned?
