Alternator Voltage
Old 07-02-2013, 07:41 PM
Fall Line's Avatar
Default Alternator Voltage
While doing my 2Bar SD tuning I noticed my Voltage starts out at 14V cold then down to ~12.8 when hot. Seems like I need an Alternator but thought I'd see if anyone else had input since I'll have to pull the procharger. Also, I'm seeing 0.3V higher with a meter at the Alternator so I'm going to replace the battery cables.
Old 07-02-2013, 08:14 PM
9-Second Club
Ed Wright's Avatar
If it's charging it will stay 14 volts or more. Belt could be slipping when hot. That effects your air/fuel tuning also.
Old 07-02-2013, 08:33 PM
Fall Line's Avatar
Thanks, 14V was what I thought. It's not slip (new belt and voltage doesn't vary with rpm) so it must be the Alt.
Quick Reply: Alternator Voltage
