Bad Wheel Sensor Help!!!!! 98 Corvette
Old 04-28-2004, 02:52 PM
98LSVETTE's Avatar
Default Bad Wheel Sensor Help!!!!! 98 Corvette
I pulled the troubleshooting code for my traction control system of C1225H, telling me that their is a bad wheel sensor. I'm being told by the dealer that I have to buy the whole hub assembly. They are giving my a price of $690.00 So, does anyone know if this is false info or if correct where I can this item a lot cheaper. Much appreciated Jim
Old 04-28-2004, 03:05 PM
crainholio's Avatar
I'd disconnect, clean the contacts both on the connector and the sensor, and reconnect the wheel sensor in question. My favorite cleaning solution is aerosol electronic contact cleaner, usually available at Radio Shack.
They live in tough conditions, so if the rubber seal on the connector fails or isn't seated correctly things get dirty quick.
Old 04-28-2004, 03:33 PM
98LSVETTE's Avatar
Thanks! I will check that.
Old 04-28-2004, 08:40 PM
wrencher
wrencher's Avatar
Well if the windings on the WSS are bad you'll need the whole piece.
Tried GM parts direct?
