Very simple Pressure Plate question, need help soon, middle of install.
When I compare my old stock pressure plate to my new one, the new one's fingers or springs are sticking out more than my stock ones. In other words, when I lay the two pressure plates side by side on a workbench with clutch face down and spring/fingers up, the fingers on the new one are sticking up higher than the stocker, but all other parts of the pressure plates match up. It's not just a mm or two, it's a pretty big difference.
Is this OK?
I can get a camera if you guys need it and think it'll help.
I have it all torn apart and this is a big deal for me so looking to hear from someone if this is normal or not before I can proceed, as I REALLY REALLY don't want to pull this transmission out again all by myself.
Side question: none of the FAQ's mention to use thread locker on the flywheel or PP bolts so I'm not, unless someone here thinks that's wrong.
THANK YOU.
Is this OK?
THANK YOU.
Thanks for the reply.
Yep you are right. Once I got the PP torqued down to the flywheel it pulled the fingers way in to near what the tired one was.
I went ahead and used thread locker on the flywheel and PP.
One thing I didn't expect was that when I tried mating the trans to the bellhousing, looking in the gap I saw that the last maybe 1/2 inch the throwout bearing was already touching the fingers on the PP, and that is why it had a tough time on that last 1/2 inch because I had to overcome the spring on the throwout bearing somewhat apparently for the last 1/2 inch of the trans install. It was a new TO bearing so I had no line installed, I wonder if some of these people with problems mating the trans just need to crack the bleeder to release pressure so the TO bearing is free to move in...? Otherwise I guess you're fighting the PP fingers on that last 1/2 inch? Just a theory.
I don't remember reading that anywhere, everyone always just the last 1/2 inch is tough, I thought they were all talking about the dowel pins or something.
I guess it's OK because even though the clutch pedal engages a bit low, it is releasing and engaging, I didn't bleed it a whole lot yet.
If any of this sounds incorrect or a sign of a problem, PLEASE LET ME KNOW, thanks again.
I think a shim is needed when the PP fingers don't reach the throwout bearing if I understand it correctly, I had the opposite situation, my fingers were touching my TO bearing about 1/2 inch from trans-to-bellhousing touching, so I think that last 1/2 inch I was fighting against the TO spring (fluid line was empty).
I installed the tick speed bleeder and it's awesome. I first ran clear tubing into the straw hole of an old McDonalds cup (worked awesome) and once the fluid got clear I just ran the tube right into the master cylinder so I didn't need to refill as much and just pumped away. Tons of bubbles came out.
I'm not sure I'd tackle that job again, took like 4 hours to get trans out and another say 5 to get everything back and bled, and that's some hard labor. I think I'd consider paying someone next time.
