LS1 Injectors Need Help
Old 07-08-2013, 10:34 PM
sdime_racer's Avatar
Default LS1 Injectors Need Help
Im running stock ls1 injectors and a Airtex E8228 Inline fuel pump. The pump is 38 GPH and 125 PSI. How big injectors can i use without changing fuel pumps?
Old 07-09-2013, 07:02 AM
LS1MCSS's Avatar
You need to size the injectors to the HP of the motor, not the size of the pump. The pump also needs to be sized to the HP of the motor. Do you know what HP the pump is supposed to support?
Quick Reply: LS1 Injectors Need Help
