back to stock
back to stock
my speakers are shot, and it turns out the previous owner cut the harness off all 6 of my speakers (camaro monsoon) and now the speakers are blown. i purchased stock monsoon speakers off a member and want to revert back to stock, as the monsoon speakers were more than enough for me (my wallet). but seeing as all the harnesses are cut, its not longer plug and play. i need to purchase the harnesses again, and i swear ive looked through the stickies and havent seen part numbers for them. can anyone help me out?
Ungrounded Moderator
The connectors are extremely expensive:
12101854 - Door speaker connector $68 retail
12101825 - Sail panel speaker connector $32 retail
12085208 - Hatch speaker connector $51 retail
That's $302 just for connectors - you might want to try a junk yard instead of the dealer.
Save the manuals!
The connectors are there primarily for ease of assembly at the factory, so you don't really need them to get the job done. You can direct wire the new speakers. Just make sure you use mechanical clips or crimp connectors (vs. solder joints) if you need to extend any wires.
I also highly recommend you invest in aftermarket sail panel speakers now. 99.9% chance your pulled speakers are already torn.
wow this wouldve been great to know beforehand haha. ok well fortunately i just got a promotion thats doubling my pay, so i guess now i can stop being cheap. that sucks its so freaking expensive just for the pigtails/harness.
If you're even considering spending $300+ on connectors, stop and think about replacing the speakers. Both Kee Audio and Double D Mods (sponsors here) have complete speaker packages for $300 or less that will eliminate the need for the OEM connectors AND give you better sound at the same time.
