WBO2 Install Questions
I have HPTuners but I don't have the pro version so I'm trying to wire my WBO2 through the EGR for logging. I understand the brown wire is the input, but can I run the WBO2 ground through the EGR ground? From the pin sheets it looks like EGR grounds at the PCM so this shouldn't be a problem right?
Also, how did you guys run the wire for the sensor and mount the controller? I have long tubes and anyway I can think of running the sensor wire has the controller dangerously close to the primaries. I'd really like to avoid drilling a hole in my floorboard but if that's the way to go I'll do it.
