having clutch issue need some opinions
Car is a 2000 trans am i just gotnit a couple days ago and first thing i noticed was i can not grab gears at high rpm at all just hits a wall no matter how hard i shift. Well today i was driving in traffic and started noticing my clutch pedal was lower and lower at every light untill it was only about 2 inches off the floor so i got on a road with no stops and left it alone and it came back up about halfway. When i got home i shut the car off and pumped it a couple times and it came back to.the top like normal. I pulled the cap off and the fluid is up to the bottom of the rubber piece in there so i dont think i have a leak and the master looks dry.. i have no.problem pulling the trans to swap the slave but i wanted to get some opinions first..
I'm having a similar issue, car won't shift above 5000rpms without the pedal sticking to the floor, can't disengage the clutch...I tried the drill mod, didn't fix it, so I just ordered a Tick adj master cyl to see if that fixes it...it's been the fix for many
Yeah im thinking i may start at the MC as well.. the more I read its about 50/50 between the slave and master..Guess there's only one way to find out.. ugh where's my credit card lol
