PLX wideband shows LEAN then works off and on
Having a problem with my plx SM-AFR DM6. It will show LEAN on the gauge for a while then it will start working for a while then it may go back to showing LEAN. While showing LEAN it will show AIR if I enter DFCO. This kind of issue screams loose connection to me, but I can't find one. There is really no rhyme or reason to when it does it. Any ideas? It has worked fine in the past.
