Swap progress
Swap progress
So I started a thread in general discussion but decided that a new thread over here would be better as I go about my build.
For starters I am putting this:
into this:
I tried to run a compression test before pulling the motor but after trying to get the last plug off scrapped that idea and will do one with it on the stand.
It had a weird vibration under moderate load when the clutch was released. It would also rarely kick itself out of 4th gear when the rpm's where way off. I am thinking this is my issue, bad pilot bearing and worn input shaft:
Finally, It seems to have tons of sludge on the bottom of the bell hosing. It seems to be oil but there doesn't appear to be any on the clutch/flywheel. is there a cover behind that this is likely coming from?
into this:
