fuel pump / no fuel pump - question
Old 07-22-2013, 11:04 PM
1970's Avatar
Default fuel pump / no fuel pump - question
Planning a LS install in my 1970 Chevelle.
Have 5.3 engine and 4L60e and gas tank and pump, and more.
Put a SBC into the car last week so I can have some summer fun and do the big swap over the winter.
Now have a fuel line leak, so I am thinking of installing the new stamped steel gas tank that has a pump inside it for the LS engine.
I know that pump has way too much pressure for the carb fed small block 350.
Is there a standard fuel tank pickup I can put into the tank so I can run the old style engine for the summer?
Thank you,
Charles~
Old 07-23-2013, 01:05 AM
ls1nova71's Avatar
You could just take the pump out of the sender alltogether and put a piece of fuel line in its place. A piece of steel fuel line held on with a short piece of hose and a couple clamps should do the trick.
Old 07-23-2013, 08:18 AM
usdmholden's Avatar
Alternatively you could swap in an entire return style efi fuel system with an adjustable fuel pressure regulator and turn the fuel pressure down to whatever it needs to be for the carb. You will have to find an AFPR which works at that low a pressure though, there won't be many.
Quick Reply: fuel pump / no fuel pump - question
