Head/Cam Combo Kit
Head/Cam Combo Kit
Category: Engine - Intake/Fuel
Price: $1234
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird, Corvette, 04-06 Pontiac GTO, 04+ Cadillac CTS-V
Location (State): AL
Item Condition: Used
Engine: LS1/LS6
LS Engine?: Fits LS Engine
1. Cam-Cam- BNIB Competion Cams P/N is 54-000-11Serial # Z 5039-12 ADV Duration Int/Exh 285/291 Duration@.50 235/242 Lift .620/.610
Lobe Sep 113.0 +2
2. Head Gaskets- BNIB Cometic head gaskets P/N H1518SPF040S
4.085 bore .040 MLS Head Gaskets
3. Heads- Used but completly rebuilt by Patriot Performance- Heads are Patriot Performance CNC Ported Stage 2 P/N 2033. All valves, retiners, locks, were replaced as well as a new valve job. Have been stored in the bags and boxes inside since rebuild. These heads provide up to a 65 cfm improvement over stock OEM versions. The 59cc chambers, will increase the compression on a stock LS1 from 10-1 to 11-1.. The Stage II heads feature 21-4N 2.055” intake/1.57”exhaust stainless steel valves, with Original Patriot Gold Dual .650” Lift springs, titanium retainers, Super 7 machined locks, custom honed bronze guides, machined spring bases, and viton rubber seals.
Technical Specs:
Combustion Chamber: 59cc
Intake Runner: 227cc
Exhaust Runner: 70cc
Intake Valve: 2.055"
Exhaust Valve: 1.57"
Max. Valve Spring Lift: 0.650"
Spring Pressure Closed: 135 lbs. @ 1.800"
Spring Pressure Open: 375 lbs. @ 1.090"
Retainer Material: Titanium
Valve Seal Material: Viton
Valve Guide Material: Manganese Bronze
Valve Job: 5-angle
