LS Short Block world record big tire Rx7 roller
Year: 1984
Make: Mazda
Model: RX-7
Price: $5000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): MO
Color: Black
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Comes with:
Narrowed 9" w/ aluminum center section 33 spline axles and a full spool
Strange double adjustable coil overs
4 link
Wilwood brakes on the rear
-All the above stuff cost what I am asking for the whole car and only has a couple thousand miles on it-
Full hot and cold side turbo kit
Radiator with new BeCool radiator fans
Custom built 27 gallon fuel cell
3 walbro 255lph pumps
-10 line
Fuel system will support ~1000 whp on e85
Jegs racing seats
15 x 15 Weld prostars at the back sprayed black
Has a sheetmetal dash with aftermarket gauges, has a couple holes for more gauges already cut
Removable steering wheel
10 point cage
Suspension Travel limiters
Also has a slam bar to protect the oil pan
Front end comes off pretty easily with a few bolts for easy access to everything up front
Doors can also be easily removed
Also has 2 different sets of springs for the front for different spring rates
Currently has 33 18.5 15 Et streets but has had larger hoosier 33 22.5 15 QTP. Tires have decent tread they are just a little old.
Lexan windows all the way around, (could stand to be replaced)
With a 5.3 turbo setup the car weighed 2600lb with driver
Hooken Chassis has been through the car and made some adjustments
I drove the car on the street with no problems, same with the previous owner.
Here's a video of the car with the turbo setup in it
I'm asking $5000 obo
I am sure I'm forgetting some stuff, feel free to call or text me anytime with any questions or for more pictures of the car. If I don't answer, leave me a message. Phone #: (816)808-7298
