Notices
Parts Classifieds This an archive of the older parts classifieds, please create a new listing in our Marketplace.
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Standalone harness for 99-2003 Vortec 4.8 5.3 6.0 LS1
Old 08-01-2013, 09:30 PM
GimmeLSx's Avatar
Default Standalone harness for 99-2003 Vortec 4.8 5.3 6.0 LS1
Category: Engine - Electrical
Price: $270
Location (State): MI
Item Condition: Brand New
LS Engine?: Fits LS Engine
Schwanke standalone harness for manual/non-electronic transmissions and drive by cable throttle body. Four wire hookup: full time battery, switched 12v, and two grounds. Also has diagnostic port with check engine light and fuel pump relay and fuel pump power plus the following connections: left and right coil modules, left and right front O2 sensors, front and back knock sensors, crank sensor, vehicle speeds sensor, map sensor, throttle position, coolant temperature, cam sensor, idle air control, alternator, and 5 wire MAF. This harness is set up so that the injector harness is separate and can be changed out easily, between LS1, Vortec, LS3, etc. injector types. It does NOT come with the injector harness but one can be bought for around $60. No ECM either.
This is a good quality harness that is hand built using OEM weatherpack connectors. It bought it a couple years ago but it was never used or installed. All connections are clearly tagged. As of right now I do not need and would be willing to sell it for $270 shipped to your door.
Old 08-01-2013, 11:44 PM
itsmillertime's Avatar
What is the current injector harness for? Diameter of maf?
Old 08-02-2013, 09:20 AM
GimmeLSx's Avatar
It does not come with an injector harness but you can get one here: http://www.schwankeshortblocks.com/shopping/?ic=1614
The MAF measured 3.5" id with a dial caliper. I believe that is about 90mm.
Old 10-09-2013, 06:47 PM
GimmeLSx's Avatar
Looking to unload this to free up money for my current project. $270 shipped, no MAF.
Old 10-09-2013, 06:51 PM
GimmeLSx's Avatar
Just a note: the knock sensor wires have been split into separate connections for block mounted sensors.
Old 10-09-2013, 07:55 PM
7beast's Avatar
sold to me thank u sir!
Old 10-09-2013, 08:10 PM
GimmeLSx's Avatar
SOLD!!! Thanks Saul, thanks tech.
Quick Reply: Standalone harness for 99-2003 Vortec 4.8 5.3 6.0 LS1
