1999 5.3 truck pcm EGR for Hptuners
I am going to use the EGR for my wideband. I just want to make sure I connect it correctly to pcm. I did a search but I couldn't find the answer I was looking for.
Pin 55 on blue connector (egr pintle position sensor signal)is what I have seen to connect to.
Pin 48 blue connector(egr pintle position sensor 5v reference)
pin 23 blue connector(egr sensor ground)
I have a LM-2 wideband
1992 chevy truck with 2004 5.3 LM7 1999 pcm.
Do I just connect to pin 55 so I can use hptuners(not pro version) or do I also need to connect pin 23 for ground?
I will be adding my a/c request so I want to get the wiring for the wideband done at the same time while I have everything apart.
Thanks Joe
Thanks Joe
