Opinions on buying this N20 kit second hand
So I'd like to purchase this Brand X kit second hand off of a member on here
https://ls1tech.com/forums/parts-cla...it-extras.html
Being a nitrous noob however, I'd like to get some opinions on whether or not it's right for me, I'd like to let him know shortly. It'd be about $1300 for everything he has brand new, I double checked that. The car its going on is a 00' SS Camaro M6, Full bolt ons, SI5 cam, LS6 intake with 95,000 miles, I don't think I'd spray anything more than 100 shot. Mainly what I'm worried about is the insanely stout stock 10 bolt *sarcasm. Also I'd like to do this as safely yet cost effective as possible so would anything have to be improved in the stock fuel system?
If you are running the stock fuel system, then you will probably want to upgrade the fuel pump and injectors, and run a different spark plug. Plus you will need a way to pull some timing. I'm running the stock 10 bolt rear with a HCI 370ci LQ9 plus a 100 shot, and am not worried because I know how I drive.
