Help offset size???
Help offset size???
I need a little help here. I've been searching but cannot find what I am looking for. I have a 2012 45th 2ss car with the factory 45th wheels on it. 8"*20" front and 9"*20" rears. I need to know does anyone know or know how I can find the offset of these wheels? I am looking to get different wheels but I am finding most are asking what offset do I want? I want the wheels and tires to move outward a schoch to get the wheel to not be so tucked under the car. i am looking to go 9" up front and 10" wheels out back for my daily driving wheels. I like the way the ZL1 wheels and tires sit on those cars. I know they are wider wheels.
Thanks Rob
Thanks Rob
Your current wheels have a +35 for the 20 x 8s, and a +40 for the 20 x 9s.
Here's some good options:
front
20 x 9, +30 to +20 offset
20 x 10, +35 to +25 offset
rear
20 x 10, +35 to +20 offset
20 x 10.5, +40 to +25 offset
Tires
Front
20 x 9, 245/45/20 .. 255/40/20 .. 255/45/20 .. 265/40/20 .. 275/40/20
20 x 10, 275/40/20 .. 285/35/20 .. 295/35/20 .. 305/35/20..
Rear
20 x 10, 275/40/20 .. 285/35/20 .. 295/35/20 .. 295/40/20 .. 305/35/20
20 x 10.5, 275/40/20 .. 285/35/20 .. 295/35/20 .. 295/40/20 .. 305/35/20 .. 315/35/20
front
rear
Tires
Front
Rear
Sweet Thank You! But one more question. Can I use the stock tires that are on the car now when I go up to a 9" and 10" rim from the 8" and 9"?
Stock tire sizes are.....
Front 245/45 ZR20
Rears 275/40 ZR 20
I don't want to have to buy new tires yet as these have only 6000 miles on them in over a year and a half. If so are they going to look goofy or wrong? I see you say I can use the stock rears on a 10" rim but the front tires are not in the catagory you listed for the 9" fronts.
Thanks again Rob
Front 245/45 ZR20
Rears 275/40 ZR 20
Thanks again Rob
Yes you can. Most tire manufactures recommend up to 9" wide wheel with a 245/45/20.
With the 275/40/20 tire you can run it on up to a 10.5" wide wheel, and so manufactures recommend up to a 11" wide wheel with their tires.
FYI, with the 245s on a 9" wheel you'll need to be more careful pulling up next to a curb. I forgot to add the 245/45/20s(and a few others) to the list that's all.
