Hydraulic failure?
Old 08-13-2013, 11:53 PM
richard_956's Avatar
Default Hydraulic failure?
I've heard things left and right about clutch issues and I just need some help on why my car won't shift into any gear with engine running. Now it's not a leak because I still have full fluid. Although I will state that the dot 3 is dark almost black. Is this a clutch issue involving the removal of my trans and replacing clutch master and slave exct. or a bleeding and or flushing of the fluid issue due to air
Old 08-14-2013, 08:06 AM
SPEC-01's Avatar
It's hard to say for sure because it seems that you have a few things going on. The first thing I suggest is flushing and refilling the hydraulic fluid. This is relatively easy and cheap to do. I recommend the use of a mighty-vac or pressure-bleeder to aid in getting all the burned/old fluid and air out. Give it a try and let us know what you see as the result and we can proceed with trouble shooting. Thanks!
Quick Reply: Hydraulic failure?
