Ive got to be close to the point of no return (upsidedownville)
Old 08-18-2013, 09:58 PM
Blue Knight's Avatar
Default Ive got to be close to the point of no return (upsidedownville)
Ok whats it worth?
81 malibu
5.3, g5x1 cam, vic jr, holley 750 dp, arp rod bolts and the rest is stock.
msd 6ls
tci th400, ultrabell, tci 4000 converter with anit ballooning plate.
promatic 2
3" cromoly drive shaft
baseline upper adjustment buckets.
trz arb
ford 8.8 (stock) double adjustable uppers and lowers. strange double adjustable shocks.
mainline nitrous kit with bottle warmer (pressure switched) and remote bottle opener.
clean car manual everything except brakes (new everything) and it has a heater and radio. Bench seat and 3.5" lift off hood. 8an feed and return. walbro 255 exturnal with a mallory bypass regulator.
weld prostars 15x8 rears and 15x7 fronts. set up for 275/60 tires (brand new not mounted m/t drag radials)
Thanks.
Old 08-18-2013, 09:59 PM
oh yeah...its a 2 door
Quick Reply: Ive got to be close to the point of no return (upsidedownville)
