How to run a return line threw the evap ?
I don't have pics but I can explain. On the driver side rear by the fuel filter is a block with fuel lines going to it. One of them goes back to the sender as a return.
You need to remove that line and plug the block. Then just simply move the evap line at the sender over to were that line used to be.
You obviously need fuel rails with a return. The 97&98 c5 vette rails have a return. That's what I used. You can even put a 1:1 regulator on the factory rail.
