Relay panel for standalone EFI harness
This is the most affordable relay option I have found for building a standalone harness.
Get these from most any 90's ford vehicle. They are located behind either the driver and passenger side headlight in the engine bay.
Pretty slick! I like the 94-96 Caprice/Imapala fuse and relay boxes. I noticed in the U-pull that the newer Impalas have 2 of the same boxes. If you want relays packed together, that Ford unit looks slick!
