Injector sticking open after tune
Old 08-23-2013, 05:13 PM
ERKEL's Avatar
Default Injector sticking open after tune
Ive got No. 6 injector sticking open after a tune and harness re-wire. Ive swapped injectors with another set since they have set for awhile. Same issue. Even swapped injectors around with same result. I can turn the key to ON position and that injector will open and start spraying fuel. What gives??
Old 08-24-2013, 07:02 AM
sreve's Avatar
It found a ground, tune did not cause this.
Old 08-24-2013, 07:09 AM
9-Second Club
Ed Wright's Avatar
Could be the driver or circuit in the PCM has grounded. It's simply a coincidence it happened then. Nobody could tune one to do that if they wanted to.
Quick Reply: Injector sticking open after tune
