The Stumper
The Stumper
I put a 6.0 in my 79 malibu about 3 years ago. It has an intercooled procharger blowing through a quick fuel carberator and an msd box. Once installed it ran fine, fast foward 3 years, it doesn't. I drained the fuel cell and replaced the gas and started it. It seamed to idle ok but would break up at 2 grand. I tried to tune the carb to no gains. I down loaded the msd curve to make sure it didnt fall out during its sleep. It was still there. I unhooked the procharger and I replaced the carb and it still is breaking up at 2 grand. Any direction of what to do next would be appreciated.
I assume fuel pressure is good when it breaks up. Maybe a clogged filter.
Also check the plugs.
Try running with a lap top hooked up to the MSD box and see if it shows anything breaking up. Maybe a ground/power wire corroded so you are no longer getting full voltage to either the box and/or the coils.
Clean your battery posts while you are at it, even if they look clean.
