Oil cooler plumbing with Vortech?
Hey guys I'm thinking about trying to plump an oil cooler somehow with my vortech kit I'm about to install. Living in Florida I see hot temps all year. Have any of you guys dont this? Would it be okay to run the return line from the head unit to a cooler before it returns to the oil pan or is there a better way to do it? Thanks
You need pressure to push oil through a cooler. If you run it on the return line it will just pool in the cooler/lines. I wouldn't worry about an oil cooler on the blower even in the FL heat.
