new XDF for obd-i LT1
for anyone tuning their lt1 with tunerpro,
i'm going to clean up, comment, categorize, and add some necessary stuff to the XDF for EE.
since half the damn bin is transmission parameters, putting them all into their own category makes browsing around the xdf much easier. i also seperated all the error code switches.
i've also added (obviously should be considered beta):
- blm locker as a patch (no more seperate exe)
- block learn mode and crankcase purge enable coolant temperature
- cl mode vs maf afgs, and O2 rich/lean threshold vs. cl mode. yes, you can now tune closed loop part throttle AFR with tunerpro, like tunercat guys have been doing for years
i hope someone finds it useful. i'll be adding more soon
http://resfilter.net/files/carstuff/...DF_CURRENT.zip
