whats THE best plug GAP for 12psi boost ?
Old 08-31-2013, 07:05 PM
red 454's Avatar
Default whats THE best plug GAP for 12psi boost ?
HI guys
what plug gap would you recommend for a L98 with mid range cam and mast 11 deg heads and a maggy 2300 on 12psi I have come down from 35thow to 28thow is a lot better now in 3rd
1st 2nd 3rd are very strong but forth feels like the spark is still blowing out if I WOT under 4000 rpm if you ease it on it seams fine
plugs are NGK TR6 v power
thanks
Old 08-31-2013, 11:09 PM
gm-ntmr's Avatar
Kind of beating a dead horse every car is going to be diffrent best way is to just start low 22 and go up until it blows out spark. My car was doing the same thing but I found out I had loose grounds. Might use the search function their must be at least 10 diffrent posts on this subject.
Old 08-31-2013, 11:14 PM
red 454's Avatar
CHEERS
thanks
Quick Reply: whats THE best plug GAP for 12psi boost ?
