divided turbo on undivided turbo manifold
Old 09-01-2013, 09:15 AM
ISprayOnU's Avatar
Default divided turbo on undivided turbo manifold
Im buying a trick performance turbo manifold and its a undivided flange. The turbos I been looking at has the divided flange on the turbo. Question is can I put the divided turbo on a undivided turbo header flange?
Old 09-01-2013, 09:26 AM
allumini's Avatar
The short answer is yes you can. I have been looking in to this for a pair of Borg warner s366 . The ar for the divided .91 should be smaller than the open .88 and should spool sooner . This is theoretical and has been proven on 4 cyl. applications. Such as a test on a s2000 with a back to back test. The only issue that may arise is choking in the top end.
Old 09-01-2013, 09:54 AM
ISprayOnU's Avatar
I was looking at the s480 turbo or turbonetics 7875 turbo. All I see is there turbo have just the divided. Do they make undivided ones ?
Old 09-01-2013, 10:25 AM
ls1curt's Avatar
It will be fine
Quick Reply: divided turbo on undivided turbo manifold
