Histograms Populating Sporadically
Old 09-01-2013, 09:56 AM
cptinjak's Avatar
Default Histograms Populating Sporadically
I was out tuning VE tonight. After 4 or 5 rounds of logging, I started seeing an issue where my AFR Error Histogram isn't populating for periods of time. In the log attached, the first instance begins at 12 seconds. Although the RPM, MAP, and AFR error data is updating in the table, the histogram "freezes" with the 800rpm, 75kpa cell highlighted, but not updating. It stays stuck until 23 seconds when it starts updating properly again.
I am not positive, but it seems to be related to my throttle input. stabbing the throttle and releasing it seems to bring it out of its "frozen" state for a moment.
Can anyone shed any light on this? I'ts got me scratching my head. I am doubting my logged data is any good if it's only updating part-time.
Couldn't upload the .cfg file. change the config.hpl extension to cfg and it should work.
Thanks,
Jack
File Type: hpt
File Type: hpl
File Type: hpl
Old 09-01-2013, 06:53 PM
LS1TECH Sponsor
foff667's Avatar
hard to tell, maybe a filter you have applied or something.
Old 09-02-2013, 12:58 AM
cptinjak's Avatar
What kind of filter? I'm not sure what you mean.
Jack
Old 09-02-2013, 07:08 AM
Fall Line's Avatar
You are filtering all data with an AFR<14.62.
Old 09-02-2013, 09:22 PM
cptinjak's Avatar
Holy ****. Thank you. I feel dumb but thank you.
Jack
Quick Reply: Histograms Populating Sporadically
