who uses hptuners with aem uego wide band?
Old 09-02-2013, 10:19 AM
SPRAYED 01's Avatar
Default who uses hptuners with aem uego wide band?
I'm having an issue that the hp log reads about .3 to .5 higher afr then the gauge. This is making it extremely hard to dial in afr as i don't know which one to trust.
I'm thinking the gauge is right as the car was professionally tuned and it cruises and idles right around 14.7:1 on the gauge and the laptop reads 15.2ish afr. Also my commanded afr is a lot closer on the gauge then laptop. Ve seems to be in line, the ltft are all 0 and its a proven setup.
All I did was add a meth kit and Im trying to tune afr for the addition of meth.
Any ideas?
Old 09-02-2013, 12:30 PM
SPRAYED 01's Avatar
I just grounded pin 5 to the same ground at uego. Then i unplugged the sensor and the gauge reads 14.8,hp reads 15.0
Old 09-16-2013, 07:38 PM
2000 TA owner's Avatar
Adjust the pid 10 to 9.8 this worked for me
Old 09-16-2013, 08:59 PM
SPRAYED 01's Avatar
Ya did that. They match better now.
Quick Reply: who uses hptuners with aem uego wide band?
