S14 kouki ls1 Starting Problems
Old 09-10-2013, 12:09 PM
s142fast's Avatar
Default S14 kouki ls1 Starting Problems
I have a ls1 off a 2002 camaro ss and the car wont start unless i floor the gas pedal and attempt to turn it on sometimes it wont even start that way because i end up killing the battery, but the car always starts in the first try if i disconnect the tps sensor. If you have any input on this problem please let me know. I have replaced the iac and tps sensor.
Old 09-10-2013, 07:42 PM
i r teh noobz's Avatar
Have you checked the TPS signal? Perhaps its wired wrong.
Old 09-11-2013, 12:18 PM
s142fast's Avatar
CHASEBAYS did my harness unless they messed up. They supposedly double checked it.
Old 09-11-2013, 01:34 PM
2muchboostNY's Avatar
^^Not saying its the issue but I would triple check it. Many people on the Nissan Forums have had issues with ChaseBay harnesses in the past. Some have had to send it back to them 3-4 times to get all of the issues worked out.
Old 09-11-2013, 01:43 PM
Lrn2Go's Avatar
^---- That's true. Wiring Specialties seems to be the go-to people for this in s13 and s14 chassis now days.
I agree... check the tps signal and make sure the sensor is good. If you're still using the stock ECU, I've heard you may need to perform the TPS re-learn procedure. Good luck!
Old 09-11-2013, 08:21 PM
BoostinIx's Avatar
Even if they had a decent rep...which they don't...still a good thing to check. Rule things out one by one.
Old 09-12-2013, 01:27 AM
s142fast's Avatar
I will check it tomorrow morning and i will let you guys know what happens thanks for the input.
Quick Reply: S14 kouki ls1 Starting Problems
