GTO Gauges
Old 09-14-2013, 01:51 PM
LSXstang94's Avatar
Default GTO Gauges
Anyone ever use GTO gauges or gauges out of a C6 vette or new Camaro on there swap?
the GTO gauges are $75 on ebay all day long and look okay plus I can modify them to fit in my sn95.
I use gauges now that are similar to autometers but I want a more factory look.
I run a PSI harness the wiring is all there and labeled
Old 09-14-2013, 01:56 PM
KENS80V's Avatar
I'm installing a C6 Corvette gauge cluster in my Superlite Coupe. You must also install the BCM from the donor car. Same goes for the GTO or Camaro cluster.
The cluster will not function by itself.
Old 09-15-2013, 01:10 AM
LSXstang94's Avatar
where would I find the bcm?
Old 09-15-2013, 01:12 AM
LSXstang94's Avatar
oh I found it, I figured there would be a way around the bcm
I mean people make mustang gauges work
maybe not though I just want something clean looking for the sn95
Quick Reply: GTO Gauges
