Notices
Vehicle Classifieds This an archive of the older vehicle classifieds, please create a new listing in our Marketplace.
Cars Search
Keyword:
Year:
(Range)
Make:
Model:
Price:
Mileage:
Private or Dealer Listing:
Location (State):
Color:
Transmission:
Drivetrain:
LS Engine?:
Parts Search
Keyword:
Category:
Price:
Part Fits:
Location (State):
Item Condition:
Engine:
LS Engine?:
1973 dodge dart 340
Old 09-14-2013, 06:13 PM
ryanj05's Avatar
Default 1973 dodge dart 340
Year: 1973
Make: Dodge
Model: Dart
Price: $10700
Mileage: 2000
Private or Dealer Listing: Private Listing
Location (State): LA
Color: Red
Transmission: Automatic
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
Super clean dart 340 sport with over 30k invested
340 bored 0.040", KB hypereutectic pistons, CR approximately 9.8:1.
Block was decked and squared. Entire rotating assembly was balanced. Clevite main and rod bearings. ARP bolts are used on the cylinder heads, rods and main bearings.
New double roller timing chain set with Mopar Performance chain tensioner.
Factory cast iron "O" heads with 2.02"/1.60" stainless valves. Chrome-moly retainers.
Lunati Voodoo #60403 cam with .498"/.513" lift and 228*/234* duration @ 0.050".
Lunati dual valve springs. Teflon valve seals. Bronze valve guides. Intake ports are gasket matched. Three angle valve job and hardened exhaust seats. Crane ductile iron adjustable rocker arms on Mancini Racing chrome rocker shafts.
Edelbrock Performer RPM intake manifold with a Holley 750 cfm, vacuum secondary, carburetor.
One inch tall four-hole spacer.
Mopar Performance distributor.
ACCEL 300+ ignition system, with built-in rev limiter.
TTI ceramic coated headers, with an inside thermal barrier, feeding into 2.5" exhaust pipes.
Drivetrain & suspension specs;
Chrysler 727 transmission, rebuilt in late 2009 with Trans-Go TF-2 shift kit. Mopar Performance deep-sump transmission pan. PTC 2800 rpm torque converter. Hurst Quarter-Stick shifter. Heavy duty transmission fluid cooler connected with AN fittings and braided stainless steel lines.
Bouchillon Performance kickdown cable.
Chrysler 8.25" rear axle with 3.91 Mopar Performance gears and Trac-Lok differential.
Four wheel manual disc brakes. (Out of a 95 Jeep)
.890" diameter torsion bars.
Factory front sway bar.
205/70 front tires on 14" x 7" Cragar SS wheels.
255/60 rear tires on 15" x 8" Cragar SS wheels.
Entire front suspension was rebuilt with MOOG parts.
ESPO +1" rear leaf springs and new bushings.
Driveshaft balanced with a new front yoke and solid U-joints.
Factory style copper/brass 3 row radiator with heavy duty fan clutch, seven bladed fan and the factory shroud.
M52 factory sunroof option as noted on the fender tag.
Viper Red base coat/clear coat Standox paint.
Welded in subframe connectors.
New carpeting.
New upholstery on the inside panels.
New upholstery on the front and rear seats.(Mitsubishi Eclipse Seats)
Modern, retractable 3-point front seat belts.
Custom built dash/instrument panel with AutoMeter gauges.
Battery mounted in trunk.
The factory underhood wiring harness was recently replaced with all new wires and WeatherPack connectors.
New windshield
I am really looking for a WS6 with less than 60k miles. 318-557-5968
Attached Thumbnails 1973 dodge dart 340-thumb_001_370_277.jpg   1973 dodge dart 340-9086686776119.jpg   1973 dodge dart 340-013.jpg   1973 dodge dart 340-016.jpg   1973 dodge dart 340-014.jpg
Old 09-15-2013, 12:04 AM
hfthe3rd's Avatar
Worth a shot but I have a 98 trans am vert, plenty of mods with 75k
Old 09-15-2013, 02:47 PM
ryanj05's Avatar
ill pass thanks for offer though
Old 09-22-2013, 02:50 PM
ryanj05's Avatar
still for sale http://cgi.ebay.com/ebaymotors/1973-...#ht_825wt_1165 for more pictures
Old 09-25-2013, 10:07 PM
ryanj05's Avatar
still have
Quick Reply: 1973 dodge dart 340
