02 Trans Am Roller 8.5 Tire car
Year: 2002
Make: Pontiac
Model: Trans Am
Price: $11000
Mileage: 82000
Private or Dealer Listing: Private Listing
Location (State): IN
Color: White
LS Engine?: Car has LS engine
Car is a 02 trans am ws6 body with 6'' vfn ram air hood and t tops
Umi suspension front and rear, rear has been converted to solid rod ends, rear strange double adjustable shocks, qa1 front double adjustable. Car does 1.3x 60ft on the back tires at 3550lbs
Moser 9'' ford rear, 3;23 gear, 5/8 studs, 31 spline axles and spool. Rear has been cut down to run a 15x10 w/ 5 inch backspace.
15x9 holeshots with 275-60 mickeys and 15x3.5 holeshots with morso ds-2 tires
Areospace space drag brakes at all 4 corners
Leash Electronic pro street wiring. Car has new wiring. All factory bcm and ecm are removed. You must run a aftermarket ecm and wiring harness for the engine control.
Driver power window still works, pass does not. Pass door was gutted to help get weight out, I do have all parts to put back
10 point chromoly cage. Car is missing a bar under the seat and funny car cage to be 25.5 legal. Certified to 8.50s this year.
5 gal cell with Weldon 2025a pump, -10 feed and -6 return
Big a2w intercooler with 8 gal water tank and pump. Intercooler was built in Dayton oh by victory fad for 2000+ hp
Car can be setup for any engine trans combo, there are no motor mounts in the car, trans mount is for a th400 solid mounted.
I know I am missing a lot, you can call for more info 513 505 7921 Tom
I am asking 11,000.00 Parts can be removed to lower price. Click link for pics
http://s885.photobucket.com/user/tom...2%20Trans%20Am
