Tubular K-member and A-arms, Tail light, Headlight control module
Category: Accessories
Price: $0
Part Fits: 93-02 Chevrolet Camaro, 93-02 Pontiac Firebird
Location (State): MO
Item Condition: Used
Engine: LS2/LS3/LS7/L92/LS9, LS1/LS6
LS Engine?: Fits LS Engine
Tubular k-member with tubular a-arms. This will fit in a 1998-2002 f-body and are direct bolt-in, and should fit in a 1993-1997 if you are doing an LS swap. I don't know what brand they are because I bought them used, someone on here might know. They are powdercoated; however they are used so they are not as perfect as when I first had them powdercoated. They are quite a bit lighter than the stock k-member and a-arms. To get the same thing from UMI is going to cost you over $900 from a place like Speed Inc. Will not separate. SOLD
Rear bumper from a 4th gen Trans Am. Paint has some light scratches and it has peeled on one side. This won't matter anyways if you have a different colored car. No cracks, broken pieces, or anything like that. SOLD
Passenger Tail light: SOLD
Tail light center section $75 shipped
Head light control module. This control the up and down of your headlights. If your headlights decide to start doing the funky chicken, then this might be the problem. Basically, if your headlights start moving independently of each other or one decides to close or open for no reason, then this might be the problem. The module is pretty expensive through a dealer, ask me how I know. $80 shipped
