Speed Inc, comes through.
Old 09-20-2013, 11:53 PM
6 Second Club Moderator
LASTLS1's Avatar
Default Speed Inc, comes through.
I went to Speed today to get yet some more fab work done. Dan made a new bracket for my crank trigger. He also welded new an bungs for my new oil pan. Replaced because of wheelie in KY at the LS race.
While I was there Jim gave the tune a tweak, .
We are going to Byron tomorrow for MDRA drag radial race. Weather looks to be good. 68 deg out. If the track holds we are looking to break some new pb. We have been having some high rpm issues, hoping the crank trigger was the problem.
Thanks again, Dan , Jim and Tom
Check back tomorrow for results!
Old 09-21-2013, 03:57 AM
Nitroused383's Avatar
Good luck and be safe! Show everyone what those little 76's can do.
Old 09-22-2013, 08:23 PM
LASTLS1's Avatar
Didn't work out. I didn't retime the motor after changing the cam crank advance. Timing was way off, I also found out that my reluctor wheel has a bunch of run out. When I get go of the trans brake the engine went into a huge misifre. Oh well, better local than Indy.
Old 09-24-2013, 01:32 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,224 Likes on 780 Posts
LS1Tech 10 Year
Fixed the ground wires, how is the car now brubber?
Old 09-24-2013, 09:18 PM
LASTLS1's Avatar
Sounds nasty again. Negitive battery terminal broke off in battery. Sounds MUCH better!!!
Old 09-25-2013, 01:54 AM
Tirefire's Avatar
What kind of high rpm issues you having. I currently have a hanging rpm (2500) this is after a tune. I'm hoping to get some answers cuz this idle is driving me crazy...
Old 09-26-2013, 10:42 AM
LASTLS1's Avatar
Too big of a hole in the throttle body or can you close your tb some? Adjustment screw?
LASTLS1's Avatar
Quick Reply: Speed Inc, comes through.
