Cadillac CTS-V 2004-2007 (Gen I) The Caddy with an Attitude...
Nitrous requirements
Old 09-22-2013, 11:23 PM
707_z28's Avatar
Default Nitrous requirements
So I just got my longtubes and CAI and eventually plan on doing a 125 shot.
What exactly do you need to run nitrous? The "kit", injectors, fuel pump?
What "kit" would you guys that have ran nitrous recommend?
I plan on getting a clutch before the nitrous also. Would a LS7 be good enough or should I just go MONSTER?
Old 09-23-2013, 12:21 AM
itsslow98's Avatar
Do a Nitrous outlet wet kit and you wont need injectors or fuel pump. I still had the stock clutch in my car without issue so I wouldnt bother until it starts slipping. There is a really good nitrous section on here for any other questions.
Old 09-23-2013, 01:04 AM
707_z28's Avatar
So those numbers you have on your sig was with a stock clutch and flywheel?
Old 09-23-2013, 01:09 AM
707_z28's Avatar
Can you post the link to the nitrous section?
Old 09-23-2013, 04:07 AM
itsslow98's Avatar
Yep stock clutch and flywheel and never had a single issue with it. I drove the car hard too and plenty of nitrous through it.
https://ls1tech.com/forums/nitrous-oxide-10/
Quick Reply: Nitrous requirements
