Year: 1971
Make: Chevrolet
Model: Nova
Price: $15000
Mileage: 0
Private or Dealer Listing: Private Listing
Location (State): KY
Color: Red
1971 Chevy Nova ss good solid. Car been in the 4's in the1/8 . Rear susp Caltrac bars Caltrac split monos Afco double adjustable shocks revalved by tinnen racing shocks 9 in ford 35 spline moser axles Moser bolt thru case, Moser spool 1350 yoke 3.50 gear Wildwood brakes all stainless brake hoses . Front susp Morose trick springs Wildwood front brakes. Tubular control arms. Afco double adjustable shocks revalved by same guy. Upper control arm mount been moved for more caster . Flaming river rack ang pinion. Cross member been cut and plated and round tube added for oil pan clearance. Cage 25.5 cert All chrome moly Car has all stock inside rear seat will still go in car Rear frame rails have had 2x3 put in them. Has frame connected all the way to front Also has bar tied down to front spring cups to cage. Wired for bbc twin turbo efi combo ( no fuel injection or ignition ) Has auto meter silver gauges Factory style black carpet. 15 galon fuel cell. wired for 2 batteries and wired for alternator Afco radiator -12 fittings. Has bolt in race sterling column. Trans crossmember set up for power glide. Car had new quarters put on it a few years ago. Has new glasstec one piece front end 4 in glasstech hood. Fiberglass doors also new And new fiberglass deck lid. Body in really good shape has one dent on drivers side rear quarter where a spring spring and the tire got into the front in a spot.about 2 in square Wheels are billet specIalties Steet lite wheels 15x3.5 in front 25 in front tires 15x10 rears 3.5 back space with 325x50x15drag radials but will clear 315x60x15s easy Asking $15000 obo make and offer all I can say is no
I have complete twin turbo kit for large frame turbos with air to water inter cooler , water tank and pump. I have everything but turbos that's custom made for this car. I can negotiate in a deal
