parts lot. everything for $100
Category: Accessories
Price: $100
Location (State): PA
Item Condition: Used
LS Engine?: Fits LS Engine
includes:
- perimeter valve cover set w/gaskets and bolts
- center bolt valve cover set w/ pressed aluminum breather plug
- center bolt valve cover set w/ machined plastic breather plug using oem o-ring
- complete rocker set excellent condition with bolts (11k miles)
- "thick" LS rear cover
- "thin" LS rear cover
- LS1 chain cover
- LS1 valley cover
- 2 set of rocker stands
- set of stock ls1 push rods
- 3 bolt cam gear w/ bolts
- front cam cover
- ls1 oil pump
- 2 oil caps
- front crank/chain gear
- MAF and miscellaneous sensors, pulled from running motors, should all work
included but not pictured :
- ls1 f-body crank pulley
- 1 set used center bolt valve cover gaskets
- ls1 coolant crossover tube
- ls1 belt tensioner
- stock ls1 cam, excellent condition
- short oil cap extension
- long oil cap extension
you get everything, must be picked up in Bethlehem, PA. i will not ship or separate items. it's local pickup, $100 cash, you take it all or you get nothing.
