FD rx7 ls1/turbo/t56
Year: 1993
Make: Mazda
Model: RX-7
Price: $1
Mileage: 5000
Private or Dealer Listing: Private Listing
Location (State): MI
Color: Gray
Transmission: Manual
Drivetrain: Rear Wheel Drive
LS Engine?: Car has LS engine
SEE BELOW FOR WALKAROUND VIDEOS
no liens*
No Rust*
No Dents*
Painted Corvette Cyber Grey met. engine bay door jams trunk jams, sunroof everything was done right at a&j autowerks in 2010 out of Charlotte, North Carolina*
Real Mazdaspeed Side skirts shaved in (very rare parts seen another set go for $1300)*
MazdaSpeed GT-C front bumper*
99 spec front signal/fog lights
R.E. rear drag spoiler*
kill switch in tail light*
shaved antenna, rear wiper, most everything*
All parts where brand new. car still needs some misc window moldings*
Car also has working Power locks,windows,roof*
Engine:
Fresh 01 LS1 with ported 317 heads with PRC .650 springs. Ported melling 295 oil pump, clevite std bearings, speed pro rings gapped for boost
( top=.030 and bottom=.022)
Stock 98 cam, new ls7 lifters, comp cams pushrods, ls2 timing chain, performance products balancer.
i got this motor and turbo kit from a member on here. it made 587 rwhp and 599ft/lbs on 11.5lbs of boost.
Turbo kit
i got this turbo kit from a member on here Kev2769. its got a borg warner turbo from bullseye S372 with an s400 frame, dual tial wastegates, tial blow off valve, truck manifolds, 60lb injectors, down pipe, custom radiator, intercooler and all piping, 2bar MAP, oil feed and drain lines.
transmission:
freshly rebuilt and upgraded t56
ls7 clutch, ls2 flywheel
tri ax handle to move shifter to correct location
skip shift tuned out
pro 5.0 short shifter
Fuel system*
Aeromotive A1000 fuel pump
Mallory 4305M fuel pressure reg. w/gauge*
-8 push lock lines*
inline fuel filters*
Rci fuel cell with fuel foam and sump*
FAST fuel rail with 60lb injectors
Suspension/ rear end*
93 body freshly redone full back half with cage and tin work done late “09”*
Custom 1pc Steel Driveshaft*
Fully Built 8.8 rear end w/ strange parts*
Strange 33 spline pro axles*
Strange Full Spool very streetable don't even notice it.*
Strange 3in wheel studs*
Late 9” housing ends*
Ford Racing ring and pinion*
Strange Fully adjustable rear shocks*
Pro Comp Top Gun 4 link*
Car can accept up to 15” wide tires*
Tin work done*
Brakes*
Wilwood Brake Proportioning Valve*
Strange Pro Race Drag Rear brake system with braided lines to hard plumb*
New stock front rotors and pads*
Cooling system*
custom radiator
16'' electric fan running off relay and ecu*
Interior
needs to be finished up.*
Custom built upper alum. Trunk space frame wraped in suede to cover tin work for backhalf work
New interior carpet
Door panels need to be replaced or fixed as the mounting tabs are missing
Dash should be wraped or replaced as two holes where cut for 10 pt cage at the pillers
New Pair of Recaro seats...pro-fiac seats with sliders $1100 each (installed)
5 pt cam lock seat belt harnesses
Brand new autometer Gauges mounted in stock locations with pro light
Loaded with all options power windows, locks, sunroof*
Misc.*
Pro standalone wiring harness with relay and fuse center*
5 point seat belt harness (both drivers and passenger)*
2001 tuned ecu and engine with speed density system (no maf)
The car has a rebuilt/salvage title. i was told it was hit in the front but there is no damage anywhere.
WHAT NEEDS TO BE DONE TO COMPLETE CAR
As the car sits, it needs about a days worth of work to get it on the road running 10's. it needs the driveshaft shortened and installed, intake and tb installed (I know of one for 320 shipped), a trans mount purchased and installed, the clutch line needs to be modified to connect to the master cylinder and the wilwood master needs to be installed (included in purchase), the clutch system will need to be bled, oil feed and return lines need to be installed, and the intercooler and piping need to be installed.
Car does not have a fuel level gauge,power steering (not bad at all, short wheel base,and lightweight), ac, or heat.
I'm not sure what to ask for as a price. looking for offers and for trades. post on here, PM me or give me a call or text 616-510-0793 anytime.
