F-Body Oil Pan Modified For Drag Racing
Category: Accessories
Price: $140
Location (State): FL
Item Condition: Used
LS Engine?: Fits LS Engine
Hopefully these pics will help describe the mods.
In the 1st pic, most of the 2 original wall were cut away to ensure most of the oil is around the pickup. I also inserted a wall to make a separate sump for the pickup and prevent the oil from rushing to the front, away from the pickup, under hard braking. The wall is positioned over the drain trough to allow flow between the F & R but at a slow rate. It worked!
The 2nd pic shows the modified baffle. Basically, I cut out the hole for the pickup and moved it forward. Couple of things to note:
1. The circle in the middle shows the barely visible 10AN male bung for the turbo oil drain.
2. The circle on top is where it is cracked.
3. The oil level feature is no longer available. Imagine most considering this probably won't rely on an idiot light
The 3rd pic shows the modded pickup tube. It is an F-body tube, extended and angled to provide the proper clearances. The bottom tab goes to main #3 and the top tab goes to main #4. The holes in the tabs are sized for ARP main studs. The package DOES NOT the windage tray. You need to use the F-body windage tray it needs a little mod at main #4. The mod will be obvious when you do a trial fit.
This was an experiment that worked well and did not cost me a lot to do. Hopefully someone can use it.
Pan
Hey... I'll be down in Orlando Next week.... Wondered if I could pick it up?
Disney area
Please e-mail or text
UR50SLO@aol.com
(574)329-6390 cell
Thanks!
Scott
Disney area
UR50SLO@aol.com
(574)329-6390 cell
Thanks!
Scott
