turbo forged 370 build. what to get and where
Old 10-10-2013, 07:08 PM
bighus14's Avatar
Default turbo forged 370 build. what to get and where
I have a stock lq4 which I plan on using the stock crank in this boosted application. I was reading on here and other sites and didn't find an answer as to which rods and pistons are better and why. A lot of guys run either wiseco pistons and eagle H-beams rods or diamond pistons and callies rods. Depending on which thread you read, they say different things as to which is better. if you have part numbers and where's the cheapest place to get them that would be great. This build is so popular, there has to be a definite answer out there.
Old 10-10-2013, 07:35 PM
yenkomike's Avatar
it depends on your hp goal but if you do some searching you will find plenty of 8 second stock lowerend 6.0 engines on boost. that is stock block,crank,rods,pistons, and rings with the gap opened up. in my searching the fastest 6.0 street strip cars I have found any amount of build info on are stock engines. the cars I found are a nova and a mustang and they are both in the 8.30s at 32-3300 lbs. its going to be hard to find info when the stock parts are so strong. jmho.
Old 10-10-2013, 08:26 PM
T76s10's Avatar
im doing wiseco pistons with the upgraded rings and callies I beam rods with stock crank. bored .030 over making it a 370. getting my parts from texas speed. bend two of my stock rods with 25+ lbs boost and lean afr so im just putting good stuff in there and making sure tune is better.
Old 10-11-2013, 10:21 AM
bighus14's Avatar
I just broke a piston skirt last week so I'm not going with stock pistons or rods. Texas speed was on my list of companies because I have their TU1 cam and loved their customer service.
Old 10-11-2013, 10:50 AM
Beanslsxnova's Avatar
I have a brand new set of diamond pistons ill sell you for cheap. I bought them from speed inc last year for a build I dint end up doing. There brand new in the box part# 11517 4.030 bore -15cc dish for use with a 6.125 rod. $600 shipped to your door
Old 10-12-2013, 03:42 PM
Texhotrod593's Avatar
Correct me if I am wrong...Isnt the TU cams spec'd from SPEED INC and not Texas Speed?
I have dealt with Texas Speed several times. I love their customer service and products! I use several others but for many parts I have ordered from TexasSpeed
Old 10-12-2013, 06:41 PM
T76s10's Avatar
I believe Texas speed sells speed incs cams now also.
Quick Reply: turbo forged 370 build. what to get and where
