What year PCM can stitch together L33+DBC+4L60 ?
Old 10-12-2013, 12:05 AM
AKtundra's Avatar
Default What year PCM can stitch together L33+DBC+4L60 ?
Researching an LSx swap into a Toyota Land Cruiser. If I were king of the world, I think I would prefer to mate a L33 to an 4L60, and convert to DBC. I am not sure this combination ever existed in nature. And even if it did, a low mileage L33 will be difficult enough to source, let alone catching lightning in a bottle, and finding exactly this combination.
Is there a model year PCM that can manage the Input Shaft Speed Sensor in the tranny, the cable TB, as well as the L33. Can a PCM be programed to link this combination together?
Old 10-12-2013, 12:55 AM
64post's Avatar
LS1Tech 10 Year
Holley HP ?
Old 10-12-2013, 08:00 AM
LS1MCSS's Avatar
The 4L60e didn't have an input speed sensor. Only output shaft speed.
Old 10-12-2013, 10:33 AM
ls1nova71's Avatar
LS1Tech 10 Year
The L33 is just an aluminum 5.3 from 2005-07, so I would think a PCM from 99-02 should work since they were DBC. Some of the newer ones still had IAC drivers in them but not sure which ones, if you do a search it should come up. Vans used DBC until at least 2006 so that is another source.
Quick Reply: What year PCM can stitch together L33+DBC+4L60 ?
